Einhell TP-ET 18 Li BL Palm Router 18V (Body Only)
- Online exclusive
- Powerful motor with variable speed control for precision
- Continuous depth adjustment with durable aluminum construction
- Edge router base enables chamfering for versatile work
- Soft grip & spindle lock for comfort & easy tool changes
- Includes multiple accessories, but no battery or charger
- Part of the Power X-Change series of tools
- 3 Year Einhell Warranty (registration required)
The Einhell TP-ET 18 Li BL - Solo Palm Router has a powerful motor with variable speed control electronics, so it adapts perfectly to the task. Continuous milling depth adjustment and high quality aluminum construction ensure precise work. The edge router base also enables chamfering of edges.
Fitted with an ergonomic, soft grip for added comfort. A plastic base plate insert protects the work surface. There is also a spindle lock for easy tool change and an LED for optimum illumination of the work area.
Supplied with: 1/4" collet sleeve, 6mm and 8mm collets 1 x Parallel Stop, 1 x Compass Tip, 1 x Guiding Role, 1 x Copy Sleeve, 2 x Spanners and 1 x Extractor Adaptor.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
Supplied as body only (no battery or charger).
Specifications:
Collet diameter: 1/4", 6mm & 8mm.
No Load Speed: 10,000 – 30,000/min.
Lift Height: 40mm.
Max. Milling Cutter: 30mm.
Weight: 1.34kg.
Einhell 3 Year Warranty on Tools and Batteries + 10 Year Brushless Motor Warranty (registration required)
To benefit from Einhell's extended warranty, you must register your product within 30 days of purchase. This includes:
- 3-year warranty on power tools and batteries
- 10-year warranty on brushless motors (with registration)
Registration must be completed by the original product user via the Einhell UK website. You'll need to provide:
- Contact details and address
- Product serial number
- Purchase date
- Retailer name and a copy of the invoice
If registration is not completed within 30 days, the standard 1-year warranty will apply.
For warranty issues outside of the UK, please refer to the warranty in the home country. If a tool has to be returned to UK, please be aware that all postage costs need to be arranged and paid by the customer.
Important Information
- Warranty claims must be submitted before the expiry date and within 2 weeks of defect detection
- Warranty exclusions apply—please see the full Warranty Conditions
- Postage costs for returns to the UK must be covered by the customer
- Axminster Tools cannot register Einhell tools on behalf of customers
For assistance, please contact the Einhell Service Hotline: 0151 649 1500.
| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Battery Voltage | 18 V |
| Corded or Cordless | Cordless |
| Cutter Speed | 10,000 - 30,000 rpm |
| EAN Barcode | 4006825664300 |
| Model | TP-ET 18 Li BL Solo |
| Nett Weight | 1.34kg |
| Sound Power Level LwA [Uncertainty K] | 88.1 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 77.1 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 0.813 m/s² [1.5 m/s²] |
- Standard Delivery* - Free
