Einhell TP-JS 18/135 Li BL Jigsaw 18V (Body Only)
113542
From £114.98 £95.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Online exclusive
  • Powerful brushless motor for longer runtime & increased efficiency
  • Soft start & aluminium base plate for safety & reduced vibrations
  • Cutting line indicator & LED light for precise illumination
  • Tool-free blade holder for quick and easy replacements
  • Dust blower & extraction adapter for clear visibility while working
  • Part of the Power X-Change series of tools
  • 3 Year Einhell Warranty (registration required)
The Einhell TP-JS 18/135 Li BL-Solo Power X-Change Jigsaw is the perfect tool for ambitious DIYers who need the perfect cut in a whole host of different materials. Powered by the Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. After registering online, the brushless motor comes with a 10-year warranty. The integrated soft start ensures high safety and protects the motor, and the stable aluminium base plate dampens the vibrations of the saw.
It also features a convenient cutting line indicator and an LED light for illuminating the cutting area. Thanks to speed electronics, it is possible to work perfectly matched to the material and application. The tool-free blade holder cuts down on unnecessary movements and allows quick and easy blade replacement.
The integrated plastic glide insert protects particularly delicate workpieces, while the anti-splinter guard ensures tear-free cuts. Optimum visibility while working is ensured by the dust blower function or, alternatively, the included extraction adapter, which allows a wet/dry vacuum cleaner to be connected.
Supplied with one jigsaw blade for wood.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied as body only (no battery or charger).
Specifications:
Strokes at No Load: 0-3,500/min.
Stroke Length: 26mm.
Bevel Capacity: 45°.
Capacity: Steel 10mm, Wood 135mm, Plastic 20mm.
Weight: 2.19kg.
Warranty Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty (Registration Required)
