Einhell TP-RS 18/32 Li BL Orbital Sander 18V (Body Only)
- Online exclusive
- Powerful brushless motor for longer runtime & increased efficiency.
- Eccentric oscillation ensures a smooth finish with high material removal.
- Speed control electronics allow material-specific adjustments.
- Soft grip, low-profile design & removable handle for optimal handling.
- Integrated dust extraction system with removable pleated filter
- Part of the Power X-Change series of tools
- 3 Year Einhell Warranty (registration required)
The Einhell TP-RS 18/32 Li BL - Solo Power X-Change Rotating Sander is powered by an Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. Once you register online, the brushless motor has a 10-year warranty. Eccentric oscillation ensures the smoothest finish with high grinding performance and high material removal rates. The power can be matched to the material and job at hand by means of speed control electronics.
The low-profile design of the random orbital sander ensures optimal handling, thanks to which the tool can be held close to the workpiece. For optimal control over the tool, the ergonomically shaped grinder has softgrip surfaces and a removable auxiliary handle.
The Ø 125mm grinding disc of the cordless random orbital sander oscillates in a 3.2 mm-diameter circle. The abrasive paper attaches securely to the grinding plate by means of a micro hook-and-loop system, and is easy to exchange.
For professional use without mess, the sander has an internal dust extraction system with dust collector and removable pleated filter. Alternatively, an external suction system, for example an Einhell wet/dry vacuum cleaner, can also be attached to the extraction connection. The on/off switch is dust-proof.
Supplied with 3 pieces of abrasive paper, one of each grit size P60, P80 and P120.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required
Powered by Lithium-ion rechargeable batteries with a battery management system for a long life.
Supplied as body only (no battery or charger).
Specifications:
Oscillating Speed: 6,000/24,000/min.
Oscillating Diameter: 3.2mm
Sanding Pad Diameter: 125mm
Suction Connection Diameter: 35mm
Weight: 1.11kg
