WeCheer Flexi-Shaft Carver for Multi-Tools
- Flexible drive shaft and carving head
- Convert Dremel and other mini power tools into powered carvers
- Reciprocating motion speed directly related to tool speed
Customers Also Bought
A neat flexible drive shaft and carving head which quickly and simply converts Dremel and other rotary multi-tools into a powered carver. The mechanism in the head converts the rotation of the shaft into a reciprocating motion at a speed directly related to the speed of the tool. Using the Flexcut RG chisels, the carver is great for detail work and the decoration of turned or other types of work. The hand piece is 23.5mm in diameter and with the tool mounted above the workstation is exceptionally manoeuvrable without the restriction of a stiff or rigid flexible shaft. Supplied complete with five chisels: two flat chisels, one round end chisel, one curved gouge and a V tool. Length of shaft 1.07m.
- For detail work and the decoration of turned work
- Supplied with five chisels: 2 x flat chisels, round end chisel
- Curved gouge and a V tool
