Axminster Professional Hinge Drill with 3 Spare Bits
From £16.58 £13.82
  5. Half Star
6 Reviews
  • For perfectly aligned hinge screw pilot holes
  • Conical spring-loaded nose piece ensures correct centring
  • High speed steel drill bits are for longevity and quality results
  • Three slots for chip clearance prevents clogging
  • Bits clearly marked with size for identification
  • Universal 1/4" hex shank compatible with all quick change systems
Ever tried drilling a pilot hole for a screw by eye in a hinge countersunk hole? 95% are sure to be off-centre with the screws ending up crooked. For perfectly aligned hinge screw pilot holes the conical nose of the bit sits in the hinges countersunk hole making it virtually impossible to drill anywhere other than in the exact centre. When pushed the spring-loaded nose retracts allowing the actual drill bit to bore the pilot hole. The drill bits are high speed steel for longevity and quality results. The nose piece features three slots ensuring there is sufficient clearance to prevent clogging in use. Each bit is clearly marked with its size for identification. The universal 1/4" hex shank is compatible with all quick change systems drill/drive systems. Simply choose the same diameter drill as you would use for the pilot holes for the screws you're using. All supplied with 3 spare drill bits.
4.50 6
