The Axminster Professional AP25FD Floor Drill is designed to provide a robust and precise drilling experience. Featuring a large cast iron table with a polished finish, it offers a strong and rigid work surface, ensuring stability during use. The spindle runs in genuine NSK ball bearings, which both increases accuracy and minimises vibration – both desirable benefits from a drill. The multi-vee type belts provide maximum grip and low vibration, contributing to an even smoother operation.
Safety is a priority with the AP25FD. The electrically interlocked chuck guard prevents accidental activation, and an integrated belt cover safety switch stops the drill from running when the cover is open. The drill also features an LED work lamp for enhanced visibility of your workpiece.
With the improved depth stop design, you can make easy adjustments for precise drilling depths. Drill control is smooth and comfortable with the one-piece cast iron handle with soft runner grips. The quality 1-16mm keyless chuck allows for quick and easy changing of drill bits, while the rack and pinion table adjustment ensures seamless table adjustments.
The advantages of a floor standing drill are often overlooked; the Axminster Professional AP25FD won’t take up your valuable bench space, which may be at a premium in your workshop.
Machine Classification
