Axminster Professional AP3327B Bandsaw - 230V
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Max depth of cut 300mm, max width of cut 410mm
- Braked induction motor and electrically interlocked doors for safety
- Rigid rip fence with magnified scale lens and accurate mitre fence
First class build quality and versatility
The AP3327B bandsaw is the perfect choice for any trade or large home workshop.
Fine Finished Cast Iron Table
The smooth finish of the table makes it easier for the workpiece to move across the table.
Solid Rigid Welded Steel Chassis
The construction of the chassis helps to keep any vibration to minimum.
Quick Release Blade Tension
This feature helps to reduce downtime when changing blades and also reduces wear on tyres.
Two Speeds
The high speed is ideal for making thinner cuts, while the low speed is best for making thicker, heavier cuts.
Guide Height Control
For quick, simple and accurate set up, the guide height is both rack and pinion controlled and features ball bearing guides.
Table Tilt Control
Rack and pinion table tilt control makes for quick and easy adjustment.
Dual Position Rip Fence
When the flat wider side is facing the table it is ideal for thinner material. In addition it also allows you to keep your fingers out of the way. Alternatively, when used with the smaller side towards the table, it is ideal for cutting thicker material and gives maximum support for veneer cutting.
Twin dust ports
The bandsaw features two ports for efficient dust extraction. This also helps to safeguard your health.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
A bandsaw is probably the most versatile machine in any workshop and often the first machine used when preparing timber. With a powerful motor, large capacities and made to the exacting standards we expect of our Professional range of machines, this bandsaw has become firmly established. It offers excellent safety features including braked motor and interlocked doors and twin extraction ports.
A rigid welded steel chassis, cast iron table and heavy duty bearing blade guides are standard, along with a rigid rip fence and precision mitre fence. One often overlooked feature is the ease of changing the blade; it has a quick release blade tensioning lever which substantially speeds up the process of blade changing. Two belt speeds offer the right speed for the job, big or small. A wide range of blades is available, all made in Axminster. First class build quality, ease of use and versatility mark this bandsaw out as a top machine for professional use. Supplied with rip fence, mitre fence and 13mm x 6tpi bandsaw blade.
N.B. This Machine requires a 16amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Professional 3 Year Guarantee
Machine Classification
Bandsaw Blade Length | 3,327 mm (131") |
Bandsaw Wheel Diameter | 430 mm |
Blade Speed | 490 & 1,000 m/min |
Blade Width Min\Max | 3 mm to 25 mm |
Dust Extraction Outlet | 100 mm |
Max Cutting Height | 300 mm |
Max Width of Cut | 410 mm |
Max Width of Cut with Fence | 370 mm |
Min Extraction Airflow Required | 1,200 m³/hr |
Nett Weight | 146 kg |
Overall L x W x H | 820 mm x 670 mm x 1,880 mm |
Plug Fitted | UK 16A Plug |
Power | 1.5 kW |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [2.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [2.0 dB] |
T Slot Size | 19 mm x 9.5 mm (3/4" x 3/8") |
Table Height | 950 mm |
Table Height on Stand | N/A |
Table Size | 585 mm x 445 mm |
Table Tilt | 5° - 0° - 45° |
Voltage | 230 V |
