Axminster Workshop Articulated Extraction Hood
111808
111808
- Useful for situations where a direct connection to a machine is not possible
- Removes dust and shavings with ease
- Moveable and stable
- Made of thick section steel
Axminster Professional Heavy Duty Variable Height Extraction HoodFrom £97.98 £81.65
Axminster Clear Lightweight PVC Extraction Hose - 100mm x 1mFrom £20.48 £17.07
Show more
Show less
This Axminster Workshop Articulated Extraction Hood is particularly good for situations where a direct connection to a machine is not possible, such as woodturning. It will remove the waste from your lathe with ease. It is moveable, stable and made from thick section steel, therefore is strong and sturdy.
The collection slot measures 400mm x 300mm and the maximum height is 1350mm.
EAN Barcode | 5052511135813 |
Hose Diameter | 100 mm |
