Bosch GTS 10 XC 254mm Table Saw
- Precise multi-functional 254mm saw with many features
- 2,100W, soft start, constant electronics, overload protection
- Integrated sliding table and expanding table top
- Max cut width 635mm, depth 79mm, sliding table 350mm
- 47°-0-1° blade tilt (depth 79mm at 90°, 56mm at 45°)
- Precise Squarelockâ„¢ rip fence, clear calibrations and quick set-up
- Storage areas for cable, spare blades and fences etc.
- Supplied with 24T TCT saw blade, mitre fence and push stick
- 3 year warranty available (registration required)
Bosch GTS 10 XC 254mm Table Saw with Leg Stand - PACKAGE DEALFrom £968.98 £807.48
Axcaliber Contract TCT Saw Blade Thin Kerf - 254mm x 2.1mm x 30mm 48TFrom £20.38 £16.98
Precise multi-functional saw with many features
The Bosch GTS 10 XC table saw is a powerful and reliable machine that it is capable of handling the toughest applications, as well as performing precise and concealed cuts.
Impressive cutting power
The multifunctional table saw features a powerful 2,100 W motor with motor brake, soft start, overload protection and constant speed electronics. Its large cut capacity with high precision and extreme power makes it very popular amongst professional tradespeople as it cuts through a variety of materials with ease.
Achieve accurate results
Tool-free lowering of the riving knife allows you to make concealed cuts. The self-adjusting parallel guide ensures that you always achieve precise results while the Pre-Cut Locator ensures you accurately mark the cut.
A highly versatile machine
Thanks to the integrated slide carriage, table widener and table extension, the table saw can be used for a wide range of applications. The integrated sliding table is designed for workpieces up to 355mm and an integrated rear outfeed supports longer workpieces. There’s also integrated carry handles in the table top for easy transportation.
Safety comes first
For added peace of mind, safely store the saw blade, assembly tools and accessories directly on the housing. Well-placed dust extraction port at the back of the machine ensure efficient dust extraction. Finally, there's a new on/off switch with emergency shut-off lever.
Large cut capacity with high precision, constant electronics and extreme power make this 254mm saw a winner. The integrated slide carriage, table widener and table extension enable expansion for workpieces in a variety of sizes. Large support surfaces ensure safe and comfortable sawing. The 2,100W motor has a brake, soft start, overload protection and constant speed for whatever material you are cutting. Expanding worktop gives up to 635mm width and at 90° 79mm depth. The rip fence is fitted with the Bosch self-aligning Squarelock™ for precision every time and the integrated sliding table with mitre fence will handle work up to 350mm. There is on-board storage for cables, blades and other accessories, so you have everything to hand. Integrated handles on the machine table top allow for easy transport. Supplied with 24T tungsten tipped saw blade, mitre fence, push stick and dust adaptor.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
Blade Diameter | 254 mm |
Blade RPM | 3,200 rpm |
Blade Tilt | -1° to 47° |
Bore Size | 30 mm |
Dust Extraction Outlet | 60 mm |
EAN Barcode | 3165140509435 |
Max Depth of Cut @ 45º | 56 mm |
Max Depth of Cut @ 90º | 79 mm |
Max Width of Cut with Fence | 635 mm |
Model | GTS 10 XC |
Nett Weight | 35 kg |
Overall L x W x H | 775 mm x 768 mm x 343 mm |
Plug Fitted | UK 3 pin plug |
Power | 2.1 kW |
Rating | Trade/Professional |
Table Height | 343mm |
Table Size | 584 mm x 759 mm |
Table Size With Extensions | 759 mm x 885 mm |
Voltage | 230 V |
