The KJD17 230V 4-terminal switch is frequently used on small woodworking machines. Rated at 18A, it will be suitable for induction motors up to 1.5hp or brush motors up to 2.5hp. Simply connect using insulated spade terminals, the connections being clearly marked for input and output. It is a no-volt-release type of switch, providing safety in the event of an interruption of power. Fitted with a dust cover and having positive action push buttons. A convenient large flap operates the stop switch function. Commonly found on benchtop thicknessers. Mounting plate size is 67 x 111mm with fixing screw holes on 85mm centres.
