PROXXON MICROMOT 60/EF Mill/Drill & 43pce Bit Set
111866
From £83.18 £69.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Equipped with a special balanced DC-motor for quiet and long-lasting operation
  • Features a ground ball bearing spindle for smooth operation
  • Infinitely variable electronic speed control for speeds between 5,000 and 20,000 rpm
  • Includes a keyless chuck for practical use with different shaft diameters
  • Supplied with 43 industrial quality bits and cutters for various applications
  • Ideal for a huge range of applications
The MICROMOT 60/EF Mill/Drill and 43 piece Bit Set is a versatile and high-precision tool designed for a wide range of applications. This includes milling, drilling, routing, polishing, cutting, cleaning, brushing, deburring, sawing, engraving, and carving. The tool is ideal for woodworkers, model builders, jewellers, opticians, and other professionals who require precision and control in their work.
This tool is equipped with a special balanced DC-motor that is quiet and long-lasting, along with a ground ball bearing spindle for smooth operation. The infinitely variable electronic speed control allows for speeds between 5,000 and 20,000 rpm, making it suitable for various tasks. It has a mains adapter and the keyless chuck is practical when working with different shaft diameters, providing convenience and efficiency. Supplied with 43 industrial quality bits and cutters. 12 - 18V.
