Restorer Tool Full Kit 230V
- Efficient material removal tool
- Eliminates the need for different power and hand tools
- Versatile for a range of applications
- Quick release roller change
- Compact for accessing tight and awkward areas
- Comfortable grip handle
- Includes a dust extraction outlet for effective debris removal
- Variable speed to suit the task at hand
- Supplied as a kit in a strong carry bag
Restorer Tool - One tool does it all
Offering a combination of speed, versatility, and convenience, the Restorer Tool streamlines the restoration process, making it unmatched in the market.
Restorer 3 Year Warranty
The Restorer Tool is covered by a 3 year warranty for parts and labour. Please call our customer service team to discuss if you have any warranty queries.
Find out more
Unmatched Versatility
The Restorer Tool is a game-changer in material removal, offering unparalleled versatility by replacing the need for multiple hand and power tools. This innovative tool can sand, buff, grind, polish, scrub, or clean any surface, making it the most versatile sander on the market.
Enhanced Efficiency
Experience efficiency like never before with the Restorer Tool, which is 10 times faster than a belt sander. Its powerful 3.5amp motor and diverse range of accessories, including sanding sleeves and rust/paint removal rollers, allow for rapid material removal and surface preparation, saving you both time and effort.
Superior Dust Collection
Keeping your workspace clean and safe is effortless with the Restorer Tool's amazing dust collection system. Simply connect a vacuum source to the output port, and the tool efficiently clears away debris as you work. This feature, coupled with high-quality accessories, ensures a dust-free and healthy working environment.
Ergonomic Design
Manoeuvrability is at the forefront of the Restorer Tool's design. Its compact and balanced structure ensures easy navigation in tight areas and around obstacles. The tool's ergonomic pistol grip allows for one-handed control, while the front palm grip facilitates vertical or overhead work, ensuring comfort and precision in every task.
Restorer Tool Sanding Sleeve 120 Grit (Pkt 5)From £17.58 £14.65
Save yourself time and money with the Restorer Tool; an efficient way of removing material, that would normally require the use of many different hand and power tools. The 420W, handheld tool is highly versatile; it can be used to buff, sand, grind, polish and clean many different surfaces including wood and metal, using the varied roller accessories. Simply change the drum using the tool-free, quick release function, to suit your chosen application. It is compact and neat for accessing tight or awkward areas, and can be used on flat, curved, wet or dry surfaces. The Restorer Tool is especially useful for furniture restoration.
Working like a drum sander the 75mm diameter x 100mm width drum is fast and effective with the chosen accessory for your task. Variable speed allows for greater control. It has a comfortable handle to ensure for a supported grip, plus has a front palm grip meaning you can work vertically or overhead with ease. It evenly distributes pressure across the tool, to allow for enhanced control and to reduce strain on your hands.
Additionally, it has a dust extraction outlet so you can easily attach a vacuum source to the output port to safely remove debris and we would always recommend a dust extractor is connected on this tool. The lock-on switch ensures power is maintained during use, whilst the variable speed dial allows you to choose your speed to accommodate for touch-ups or total renovation tasks.
Supplied with the Restorer Tool, a strong carry bag, 1 x 46 grit rust/paint removal roller, 1 x 80 grit abrasive sleeve, 1 x 120 grit abrasive sleeve, 2 x 60 grit sanding sleeves, 2 x 80 grit sanding sleeves, 2 x 120 grit sanding sleeves.
Tool Classifcation
The guarantee assumes that you have bought the correct tool for the required operation, in accordance with the guidelines, have operated and maintained it in accordance with the instruction manual. It does not cover normal wear and tear and does not cover consumable/wearable items purchased with the original product, including original drums. If the tool needs to be returned, we cannot accept if it is not returned in a clean condition.
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Cable Length | 4.8 m |
Corded or Cordless | Corded |
EAN Barcode | 853112007654 |
Model | WR352K2 (UK Version) |
Motor Power | 420 W - (230 V) |
Nett Weight | 2.67kg |
No Load Speed | 1,000 - 3,200 rpm |
Plug Fitted | UK 3 pin plug |
Rating | Home/Light Trade |
Voltage | 230 V |
