Rider Apron Plane
Rider Apron Plane
- Compact size making it easy to carry and use
- Solid cast and polished brass cap with a durable O1 steel blade
- 30mm wide blade with a 12.5-degree bevel for smooth and accurate cuts
- Ergonomic design to reduce hand fatigue during extended periods of work
- Ideal for trimming, smoothing, and detailed woodworking tasks
The Rider Apron Plane is a compact tool, perfect for fitting in an apron. It features a solid cast and polished brass cap, and a blade made of O1 steel that is 30mm wide with a 12.5-degree bevel. This plane is designed with precision and performance in mind, making it a reliable addition to any toolkit.
The ergonomic design of the Plane provides comfort and ease of use, reducing hand fatigue during extended periods of work. Its precision cutting capabilities deliver smooth and accurate cuts, making it ideal for fine woodworking projects. This versatile tool is suitable for various tasks, from trimming and smoothing to detailed work, ensuring that you can confidently tackle any project.
EAN Barcode | 5052511133161 |
Nett Weight | 426 g (15oz) |
Plane Blade Type | O1 |
Plane Blade Width | 30 mm (1.3/16") |
Plane Sole Length | 133 mm |
Plane Type | Block |
