The UJK Compact Speed Square, the perfect tool for woodworkers who need precision and convenience on the go. A smaller and more simplified version of the UJK Professional Woodworkers Square this square maintains the same high-quality, accuracy and is designed to be easily portable.
British made, compact, sleek, and incredibly practical, its compact design makes it ideal for precision work in tight spaces, ensuring accuracy where bigger squares could struggle. Perfect for detailed joints and verifying right angles. The radius on the inside edge makes it ideal for marking boards.
Manufactured in Britain, from one piece of high-quality aluminium, the UJK Compact Speed Square guarantees exceptional accuracy and durability. It is machined from a solid aluminium, anodized, and laser-etched on both sides. The vertical edge is graduated in 5mm or 1/8" increments, with accurate measuring holes that work seamlessly with a Pica pencil, allowing you to measure with precision. Opt for a Pica style, 2.8mm construction pencil, or 3-8H pencil to help with line accuracy. Available in metric and imperial sizes.
Whether you're in the workshop or on-site, the UJK Compact Speed Square handles all your marking and measuring tasks with ease and at high precision. Enjoy one of the most accurate squares on the market with portability and precision in this clever UJK tool.
