UJK Parf Plus Guide System
112024
From £249.98 £208.32
2 Reviews
Cosmetically imperfect products, unused returned items or refurbished 'as good as new' products, at a discounted rate. Our quality assurance checks are very high and occasionally, cosmetic imperfections happen. In our continuing efforts to becoming more sustainable, we're offering ‘as good as new’ products, at a discounted rate. Same quality of product at exceptional value. Show More
From £212.48 £177.07
  • UJK Parf Plus Guide System combines the UJK Parf MkII Guide system and the UJK Parf Protractor
  • Proudly British Made
  • Build a portable workstation, replacement MFT (multifunction table) top or multiple cutting boards in as little as thirty minutes or less
  • Produces a precise pattern of 20mm holes and guarantees perfect 0° and 45° cuts
  • Use with a host of 20mm dog fitting and accessories
  • Guarantees accuracy and eliminates any chance of cumulative error
  • Based on the Pythagoras' theorem for infallible accuracy
  • Straightforward to use, for a host of guiding and clamping tasks
  • UJK Parf MkII Guide System - Winner of The King’s Award for Enterprise in the innovation category 2023
The UJK Parf Plus Guide System is the perfect combination of the award-winning UJK Parf MkII Guide System and the innovative UJK Parf Protractor.
Proudly designed and British made to elevate your woodworking projects to new heights of precision and efficiency. Creating custom benchtops in just 30 minutes with 20mm accurate holes from 0-90° angles. Whether you’re on-site or in the workshop; accurate holes, right angles, perfect mitres and repeatable cuts, are available to you to custom make for custom work.
The UJK Parf MkII Guide System is a versatile jig system that allows you to create custom benchtops, portable cutting boards, or multifunction table (MFT style) tops with 20mm hole patterns based on Pythagoras' theorem. This system guarantees perfect, quick, and easy 45° and 90° cuts every time, making it an invaluable tool for both professional trades and home workshops alike. The British made MkII version preserves and guarantees the long-term accuracy of the jig while improving ease of use. It includes two Parf sticks, a drill guide, a special 3mm drill bit, and a 20mm boring bit, all designed to work in harmony for flawless results.
UJK Parf Protractor
The UJK Parf Protractor is the ultimate addition for precision woodworking, working seamlessly with the UJK Parf MkII Guide System. It allows you to create a further series of 20mm dog holes, ranging from 0-45° and 45-90°, with precise angle measurements in 0.5° increments. Made from stainless steel with high-precision laser engraving, the Parf Protractor ensures repeatable and accurate cuts every time. Proudly British made, it embodies the reliability and quality that UJK is known for.
The UJK Parf Plus Guide System is supplied with the UJK Parf MkII Guide System and UJK Parf Protractor.
British Made British Made
5.00 2
