UJK Router Table Insert for Trend T14
112999
New
From £99.98 £83.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • UJK 10mm aluminium router table insert plate
  • Pre-drilled to fit the Trend T14 1/2" Router
  • Threaded lead-in pin
  • To fit 230 x 306mm aperture
  • Twist lock insert ring supplied with wrench
  • Range of central insert rings available
This 10mm UJK Router Table aluminium insert plate is pre drilled specifically for the Trend T14 1/2" Router, for router tables measures 229 x 305mm and is designed to fit the UJK cast iron, phenolic or MDF router table tops. The insert plate will accommodate the Trend T14 1/2" Router with pre-drilled holes to fit perfectly. It is supplied with a removable central insert ring with a 38mm diameter hole with a range o other hole sizes available. This includes one that will accept a standard threaded guide bush for template routing.
The UJK router table insert for Trend T14 will also fit:
Trend: T8E, T10E, T11E, T12E, T14E
Elu: MOF177E
DeWALT: DW625E, DWE625E, DW262E
CMT: CMT1E, CMT2E
