Faithfull
Faithfull Rotary Rasp Set
SKU: 108564
£10.74
£8.95 Excl. VAT
  • 4 high carbon steel rotary rasps plus a countersink
  • For wood, plastics and softer non-ferrous metals
  • File, shape, profile or carve, 6mm shanks
The set comprises four rotary rasps and a countersink. The high carbon steel rotary rasps can be used to shape, profile or carve wood, plastics and softer non-ferrous metals. These rasps are ideal for filing and surface preparation. All have 6mm shanks making them suitable for use with most standard drills.
Set comprises the following sizes:
Cylindrical file: 12mm diameter x 30mm long
Cylindrical rasp: 14mm diameter x 35mm long
Conical rasp: 6-14mm long taper x 35mm long
Ball rasp: 14mm diameter
Countersink: 12mm diameter x 90 included angle
Pack Quantity 5
Web Attribute Set Drill Mounted Sanding Systems
EAN Barcode 5023969262987
