£279.96 £233.30
Low stock
- get it tomorrow, Wednesday 30th Sep, order within and choose Premium delivery. Delivery info
  • Lets you work almost anywhere, wide-ranging versatility
  • Starlock Plus accessory mounting gives outstanding torque transfer
  • Suitable for all Starlock and Starlock Plus accessories
Customers Also Bought
Total: £1,131.44
The Fein AFMM 18 QSL Cordless 18V Li-ion MultiMaster lets you work almost anywhere. The power, cordless freedom, wide-ranging versatility and Starlock accessory mounting all combine into one of the most useful multi-tools on the market.
This highly efficient tool gives you the ability to make use of a wide variety of accessories, blades and attachments. It is the perfect tool to have in your armoury and assist you with a myriad of jobs. With the AFMM 18 QSL you can cut, saw, sand rasp, scrape, polish, grind and more, even in places other power tools would fail to reach.
Compatible with the full range of both Starlock and Starlock Plus accessories. The Starlock and Starlock Plus fitting offer you greater rigidity, maximum transfer of torque and higher precision, plus fast, accessory changes. It takes a matter of seconds, simply press the tool against the accessory and watch it snap into place. To release just pull the top lever, it could not be easier. The high-torque motor produces exactly the same power as a comparable mains-powered version. The self-supporting motor with vibration decoupling gives outstanding reductions in vibration and noise.
The AFMM 18 QSL has a durable gearbox, constant electronic speed control with a pre-set variable speed dial. The 18V 2.5Ah Li-ion batteries feature SafetyCell technology and charge indicator, at the press of a button an LED display shows the remaining power.
Supplied with a sanding pad, three sanding sheets each of grit 60, 80, 120 & 180, scraper blade, HSS segment saw blade, E-Cut long-life saw blade (65mm), Universal E-Cut saw blade (44mm), two 18V 2.5Ah batteries, ALG 50 quick charger and Fein carry case.
  • Constant electronic speed control with a pre-set variable speed dial
  • Self-supporting motor with vibration decoupling low vibration and low noise
  • Powerful 18V Li-ion batteries with SafetyCell technology
  • Charge indicator on each battery
  • Supplied with a sanding pad, three sanding sheets each of grit 60, 80, 120 & 180, scraper blade, HSS segment saw blade, E-Cut long-life saw blade (65mm), Universal E-Cut saw blade (44mm), two 18V 2.5Ah batteries, ALG 50 quick charger and Fein carry case.
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
