FEIN 160 BiM Long-Life E-Cut Saw Blade (Starlock)
From £49.58 £41.32 was £52.58 £43.82 Save £3.00 £2.50
  • Suitable for hard and soft wood, laminate, plastic, GRP
  • Long life bi-metal blades with HSS teeth
  • 50mm length x 30mm blade width; medium width with waist for optimum cutting speed and swarf removal
  • Sharp milled teeth with an edge that really lasts
  • Blades offset to facilitate flush cutting
  • Starlock mounting for fast work progress and precise results
  • Zero slippage between the blade and the tool
  • Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adaptor
These long-life bi-metal blades are very durable and used for cutting hard and soft wood, laminate, plaster boards, GRP and plastics. The blades measure 50mm cut length and 35mm width. The sharp milled HSS teeth have a greater resistance to light contact with brick etc than high carbon steel blades and can last up to three times longer. Cutting cleanly, the tooth ensures a smoke free, no-burn cut especially on material such as MDF. The blades are offset so that they can be used to make flush cuts when needed.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
Starlock by Bosch
