FEIN 161 BiM Long-Life E-Cut Saw Blade (Starlock Plus)
508747
Low Price
Special Price £11.68 £9.73
was £12.68 £10.57 Save £1.00 £0.83
In Stock
- get it Friday 26th Apr, order within and choose Premium delivery. Delivery info
  • Suitable for hard and soft wood, laminate, plastic, GRP, nails
  • Long life bi-metal blades with HSS teeth
  • Sharp milled teeth with an edge that really lasts
  • 65mm wide cutting edge x 50mm cutting depth
  • Blades offset to facilitate flush cutting
  • Starlock mounting for fast work progress and precise results
  • Zero slippage between the blade and the tool
  • Compatible with all FEIN and some Bosch Oscillating Multi-Tools including: FEIN AFMT 12 SL, FEIN AFMT 12 QSL, FEIN AFMM 18 QSL, FEIN FMT 250, FEIN FMM 350 Q, FEIN MultiMaster, FEIN MultiTalent, Bosch GOP 280, Bosch GOP 350, Bosch GOP 300, Bosch GOP 250, Bosch GOP 18 V, Bosch PMF 350 CES and Bosch PMF 220 CE. Other brands will require an adaptor from the machine’s manufacturer
  1. FEIN 161 BiM Long-Life E-Cut Saw Blade (Starlock Plus)
Total:
£69.02 £57.52
These long-life bi-metal blades are very durable and used for cutting hard and soft wood, laminate, plaster boards, GRP and plastics. The sharp milled HSS teeth have a greater resistance to light contact with brick etc than high carbon steel blades and can last up to three times longer. Cutting cleanly, the tooth ensures a smoke free, no-burn cut especially on material such as MDF. 50mm cut length and 65mm width. The blades are offset so that they can be used to make flush cuts when needed. FEIN 161 blade.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
3.00 1
