Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
FEIN Diamond Coated Segmented Saw Blade 166 (Starlock Plus)
Code: 508754
  • Diamond coated blade for high performance
  • Ideal for small scale repair work and cutting marble, concrete
  • Remove grout from joints with ease
  • 90mm diameter x 2.2mm cutting width
  • Flush working and segmented for corner work
  • Starlock mounting for fast work progress and precise results
  • Compatible with all FEIN and some Bosch Oscillating Multi-Tools including: FEIN AFMT 12 SL, FEIN AFMT 12 QSL, FEIN AFMM 18 QSL, FEIN FMT 250, FEIN FMM 350 Q, FEIN MultiMaster, FEIN MultiTalent, Bosch GOP 280, Bosch GOP 350, Bosch GOP 300, Bosch GOP 250, Bosch GOP 18 V and Bosch PMF 350 CES. Other brands will require an adapter from the machine’s manufacturer
  • Show More
Last Few
£50.40 (£42.00 Ex. VAT)
Out of stock
Sorry, this product is no longer available.
See Alternative Options
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
A 90mm diamond edged blade for repair work on tiled surfaces, grout removal and cutting grooves in plaster, brick or aerated concrete. Diamond coating ensures long life. Depressed centre allows flush working with a surface, segmented form allows cutting into a corner without over cutting. The blade measures 90mm diameter x 2.2mm cutting width.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
Promo
Specification
Specification
Model 166
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
