Package consisting of the Dustex 25L Extractor and Dustex Floor Cleaning Kit
This ‘L’ class FEIN wet and dry dust extractor has a tank volume of 22 litres together with a comprehensive array of floor cleaning accessories which can be purchased separately. It has an impressive amount of suction and at the same time produces little noise. The Dustex 25L is fitted with an auto-switching outlet into which the power tool is plugged so that extraction is effective as soon as you switch on. The machine is supplied with a cloth filter boot, though other filters are available to order. At 8kg and fitted with four multi-directional castors, this machine is low in weight and, with its compact design, is very manoeuvrable.
The extractor is supplied with filter, fleece dust bag, 4m x 35mm diameter suction hose, adjustable airflow adaptor and 6m power cable.
The floor cleaning kit is a very useful accessory set for general cleaning. The set comprises two aluminium suction pipes, a combination nozzle with interchangeable inserts, a crevice nozzle, a suction brush and elbow.
