Cut sheet metal up to 1.6mm, aluminium profiles, copper pipes
Great for precision cutting in fibreglassed-reinforced plastics/ hard plastics
Bi-metal (BIM) blades; fine teeth, very precise and easily controlled
50mm length x 30mm blade width; medium width with waist for optimum cutting speed and good swarf removal
Narrow kerf for optimal cutting speed
Starlock mounting for fast work progress and precise results
Increased contact area ensuring maximum power transmission
Compatible with all Oscillating Multi-Tools using the OIS fitting system; FEIN MultiMaster, FEIN MultiTalent, Bosch GOP, Bosch PMF, AEG, Hitachi, Einhell, Makita, Metabo, Milwaukee, Ryobi, Skil, Dremel and others. DeWALT Oscillating Multi-Tools will require an adapter.
Bi-metal blades with fine teeth, suitable for cutting sheet metal up to 1.6mm, aluminium profiles, copper pipes etc. The blade measures 50mm length x 30mm blade width. These will also cut CFRP (carbon fibre-reinforced plastic), GFRP (glass fibre-reinforced plastic) and other hard plastics. They are extremely precise and easily controlled with an especially narrow kerf. The medium width and waisted shape offer optimal cutting speed and good swarf removal.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the blade tip. No more wasted power means faster working, minimised vibration and better results. Starlock accessories are compatible with all OIS and OIS-compatible power tools currently on the market. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
