£199.96 £166.63
In stock
- get it tomorrow, Tuesday 29th Sep, order within and choose Premium delivery. Delivery info
  • Supplied with:
  • Robust premium storage case
  • 3 x Long-Life saw blades (35, 44 and 65mm)
Customers Also Bought
Total: £273.05
The MultiMaster FMM 350QSL TOP is the result FEIN's 40 plus years of experience in the production of oscillating multi-tools. Clever design and the use of elastic dampers significantly reduce vibration and noise. The motor casing is slim and ergonomic. This machine is easy to control and comfortable to use, ensuring accurate and precise results. The 350W motor with its variable speed supplies ample power, making it ideal for working in a wide variety of materials.
The FMM 350QSL MultiMaster is part of the Fein StarlockPlus machine range. The MultiMaster is compatible with the new Starlock and StarlockPlus fittings. Starlock and StarlockPlus accessories fit perfectly without play, ensuring zero loss of power transmission giving you much faster work progress. The 3D form of the Starlock fitting gives exceptional rigidity for higher precision and better work results. With the Fein QuickIN feature, changing accessories is tool-less; a simple lever releases and locks any accessory. With Starlock, this is achievable in less than 3 seconds.
The combination of the oscillating movement and huge range of accessories makes this a true 'MultiMaster' of all trades tool. It is perfect for the professional trade user, the home renovator and all types of general work including cutting, sawing, sanding, scraping, polishing, rasping and more. The FMM 350QSL is fitted with 5m of cable.
  • Supplied with:
  • 80mm HSS segmented saw blade
  • 90mm carbide segmented saw blade
  • Carbide rasp and rigid scraper blade
  • Standard sanding pad c/w 4 of each sheets (60, 80, 120 and 180g)
  • Perforated sanding pad c/w 4 of each sheets (60, 80, 120 and 180g)
  • 115mm sanding pad c/w 2 of each sheets (60, 80 and 180g)
  • Dust extraction kit
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
