Festool Multi-Jetstream2 Pad for ETS150 Sander
- Designed for maximum suction power, even near edges
- Virtually 100% efficient, for clean and healthy working environment
- High-temperature-resistant for long service life
- StickFix system for fast abrasive changes
- Pads available in H/D hard or soft
- Super soft pad available for curved and contour sanding
- Supplied singly
The patented Multi-Jetstream2 pad guarantees outstanding sanding results thanks to its unique design.
Multi-Jetstream2 pad guarantees virtually 100% dust extraction for a consistently high material removal rate. These 150mm diameter Multi-Jetstream2 pads fit the Festool ETS150 sanders. They feature StickFix hook and loop system allowing quick and easy changing of abrasive discs.
These pads come in hard or soft and an ultra soft version. The hard pad has high edge solidity for plain surfaces and narrow edges. The heavy duty soft pad features high temperature durability for tough universal use. The ultra soft pad has an elastic structure for sanding rounded and contoured surfaces. Supplied as a single pad only.
