These high density foam blocks have four sides coated with silicon carbide abrasive. Hard wearing and long lasting they are available in a variety of grits. They are a convenient size at 98 x 69 x 26mm, a handy item for sanding off filler or repair compound. The tough silicon carbide abrasive is effective on paint, varnish, lacquer etc. Use these to gently soften edges on unfinished timber. A 120g sponge in available with a trapezoidal cross-section one edge has an acute angle and on a curve. This shaped block is ideal for sanding areas which are difficult to get to and concave profiles.
Abrasive Material Silicon Carbide
Abrasive Backing Foam
Manufacturer Part Number 201081
Abrasive Grit 60
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 4014549253717
