Festool Abrasive Systainer with Delta Granat Abrasive
112140
From £65.98 £54.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is within 3 weeks.
  • Designed to work seamlessly with your delta sander
  • GRANAT is long lasting and can be used on many different materials
  • Tough aluminium oxide and hard ceramic grit
  • Resists clogging and smearing, high quality surface finish
  • Keeps your abrasives sorted by grit size, easy to find the right sheet
  • Allows for convenient transportation, can be connected to other Systainers
  • T-LOC operating element enables easy closing, opening, and connecting with other Systainers
The ultimate solution for your delta sander – the abrasives Systainer. This convenient set is designed to keep your abrasives neatly arranged and easily accessible, making it the perfect addition to your sander. With a wide selection of grit sizes, it offers an excellent introduction to the world of GRANAT abrasives. GRANAT with its tough aluminium oxide and hard ceramic grit is long lasting and can be used on many different materials.
The abrasives Systainer includes 100x GRANAT sanding discs in grit sizes ranging from P60 to P220, ensuring you always have the right grit size at hand. It is the perfect addition to your sander as the Systainer holds 20x GRANAT sanding discs each in grit sizes P60, P80, P120, P180 and P220. Each compartment is organised by grit size, allowing you to find the required disc in seconds. The easy filling system ensures you always have an ample supply of the necessary grit size.
The GRANAT sanding discs are specially suited for VOC varnishes and hard substrates. Thanks to their special coating, clogging is avoided, ensuring a long service life. Additionally, other substrates can be processed with the GRANAT abrasive without any issues. The discs are also FSC™-certified, making them an environmentally friendly choice.
Supplied in a SYS3 M112 Systainer with 100 x Delta Abrasives in total, 20 each; P60, P80, P120, P180, and P220.
