Festool Adaptor Plate for KA 65 Edgebander
- For mounting the KA 65 Edgebander on a workbench
- Allows the user to swivel the machine from 0 – 47°
- Supplied with 15 sliding guides for safe movement of the workpiece
The Adaptor Plate is mounted onto the Insert Panel in the MFT/3 when the edgebander is used as a stationary unit. Alternatively, it can be flush mounted into a table made by the user and a routing template for the exact dimensions is supplied. Using the Adaptor Plate, the machine can be swivelled (0–47°) in the bench whilst the workpiece is positioned horizontally during edging. A set of 15 sliding guides is supplied which control the movement of the workpiece.
In addition, a set of 15 additional guide plates is supplied as an accessory and can be used to replace or extend those in use in either the MFT/3 (with the Insert Board for the KA 65) or they could be used in a separate workbench built by the user.
