Festool Circular Saw Blade Set 3, Wood 160mm x 20mm x 1.8mm kerf
- Includes three blades for fine and universal wood cutting
- High-quality carbide teeth for long-lasting performance
- Easy resharpening for consistent cutting quality
- Festool's colour-coding for quick and easy blade selection
- Ideal for equipping multiple saws or stocking your workshop
The Festool Circular Saw Blade (Set of 3) is a must-have for your woodworking projects, providing you with the essential blades for fine and universal cutting. This value pack is perfect for equipping multiple saws or keeping your workshop well-stocked. The high-quality carbide teeth ensure durability and consistent cutting performance, and they can be easily resharpened. Festool's colour-coding system allows for quick identification and selection of the right blade, making your sawing tasks more efficient and enjoyable.
This pack contains 3 blades:
2 x fine cutting HW circular saw blades: 160mm diameter, 20mm bore, 42 teeth for fine cutting wood, ideal for precise and clean cuts.
1 x wood universal HW circular saw blade: 160mm diameter, 20mm bore, 28 teeth for universal wood cutting, perfect for a variety of woodworking tasks.
