Festool CTL 26 E CLEANTEC Dust Extractor
- High performance motor with variable power adjustment
- Compatible with Bluetooth module (optional accessory)
- Integrated power tool socket with auto on/off
Customers Also Bought
The "L" class CTL 26 E filters up to 99% of hazardous dust with limit values greater than 1 mg/m³ creating a healthier and cleaner working environment. It comes with 3.5m of anti-static smooth suction hose, greatly improving efficiency. Reduced internal friction increases the airflow rate and therefore the suction power. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges. A CLEANTEC bayonet fitting ensures a secure connection to your power tool and a quick disconnection.
The machine’s control panel includes provision for retrofitting the Bluetooth module (or the compressed air module or EAA module). The integrated socket has an automatic on/off switch. Once connected the extractor automatically starts when you switch your tool on. On release of the tool’s trigger, the extractor continues to run for a few seconds to clear any remaining dust before automatically switching off.
To the rear of the machine is a unique cable storage holder, with a folding mechanism. This lets you simply remove the cable when you want to use the machine, rather than waste time unwinding it. The top of the machine features storage space for the hose and a T-LOC compatible dock allowing SYSTAINER cases to lock and stack onto the top of the extractor. Swivel castors and rear wheels offer excellent mobility and an integrated locking brake guarantees a firm stance when working.
The compact high performance turbine motor ensures constantly strong suction. Step-less speed adjustment, allows you to select the correct power for the task in hand. The 26-litre container holds a SELFCLEAN filter collection bag, this minimises clogging, resulting in constant maximum suction and ensuring 100% of the bag is utilised. The machine is has a removable main filter for easy cleaning and maintenance. A wet filter is available for wet pick-up.
Supplied with SELFCLEAN filter bag, 3.5m smooth suction hose, hose holder, Sys-Dock with T-LOC function and cable holder.
Robust, reliable, safe and durable, Festool dust extractors offer dust-free working conditions in combination with both electrical and pneumatic machines. Please ensure that any dust extractor is suitable for the type of dust produced before ordering. The "L" class is for general work. If you are routing/sanding MDF, man-made boards or all solid woods (oak, beech etc.) you should use an "M" class extractor.
- Smooth 3.5m anti-static hose for improved extractor efficiency
- Smooth outer skin means an end to snagging on edges
- CLEANTEC bayonet fitting ensures a secure connection
- L Class dry extraction, can be used wet (with accessory filter)
- SELFCLEAN filter bags ensure no loss of suction
- Top T-LOC dock for SYSTAINER cases
- Braked swivel castor wheels
