Festool CTLC MIDI I-Basic Cordless Extractor 18V (Body Only)
- A cordless extractor for cordless tools
- Complete mobility and flexibility
- Bluetooth module for auto switching with compatible tool
Customers Also Bought
Low weight, compact and full of innovation. The CTLC MIDI cordless dust extractor frees you from the constraints of mains power. Cordless tools with a cordless extractor; makes complete sense. The CTLC MIDI is a 36V machine, power is provided by using two 18V batteries, (note this is a body only tool, batteries not included). It boasts 15 litre capacity for class L dusts and plenty of suction power to cope with or sanding or sawing.
The hose stores very neatly in the top of the extractor, so you don’t need to carry it separately. The top of the CTLC MIDI is compatible with T-LOC Systainers, allowing you to connect your power cases, for easy transportation.
The 3.5m smooth hose means you no longer need worry about hose snagging on edges or inadvertently damaging a workpiece. The CLEANTEC bayonet fitting ensures a secure connection to your power tool and a quick disconnection.
The CTLC MIDI includes a CT-F I Bluetooth remote control, which communicates Festool Bluetooth battery packs for auto switching the extractor on when the tool is switched on. Access to the main filter is from the outside for easy cleaning to maintain maximum efficiency. The CTC MIDI compact dust extractor fits perfectly into the Festool 18V system.
Supplied with: High-performance main filter, filter bag, smooth suction hose dia. 27/32 x 3.5m, hose holder and CT-F I Bluetooth extractor remote control.
For wet extraction an additional wet filter is required.
Please ensure that any dust extractor is suitable for the type of dust produced before ordering. The "L" class is for general work. If you are routing or sanding MDF, man-made boards or all solid woods (oak, beech etc.), you should use an "M" class extractor.
- Smooth extraction hose with CLEANTEC hose fitting
- Neat onboard storage for hose
- T-LOC SYS dock allows easy transport of other Festool tools
- Castoring wheels for greater mobility
- Meets dust class "L" standard, for dry extraction only
