Festool DOMINO DF 500 Q-Plus Jointing Machine
- Unique jointing system using DOMINO® shaped wooden dowels
- Patented routing principle with a wide range of adjustment options
- Stop positions for hole centres 16, 20, 22, 25, 28 and 40mm
Customers Also Bought
The 'DOMINO' is a unique jointing system using rounded loose tenons to join timber giving very strong accurate and precise joints. Combining exceptional versatility with simple handling for maximum precision, the DOMINO has a patented routing principle with a wide range of adjustment options to make it extremely easy to use. The machine's fence can be adjusted to cut slots centrally in 5 pre-set timber thicknesses and manually adjusted for other thicknesses. The dowels can be placed centrally, offset, in pairs or groups. There are retractable stops for accurate positioning from the edge of the work piece. The jointer fence can be adjusted to 5 pre-set angles and is also infinitely variable between 0 and 90°. There are 6 different sizes of DOMINO available.
Various accessories increase the versatility of the DOMINO: Support bracket which is a simple right angle bracket that attaches to the base of the Domino with two thumb screws, this can be used to add surface area to the face of the Domino to increase stability during use. Trim stop to help align narrow wooden strips between 22 and 70mm centrally, plus it can also be used for mitre cuts. Cross stop, which is used for repeat hole spacing between 100 and 205mm without the need for marking the work. Handrail fence and DF-stop for reducing dowel centre from 37 to 20mm. This can be used to add surface area to the face of the Domino to increase stability during use.
Supplied as a DOMINO Q-Plus version complete with: The D5 cutter (for the 5 x 30mm) support bracket and Festool Systainer SYS3 M 187.
- Depth stops at 12, 15, 20, 25 and 28mm
