Festool DOMINO DF 500 Corner Connector KV D8/50 (Pkt 50)
104728
104728
- Pack of 50 DOMINO furniture connectors
- For furniture corner joints or ‘L’ panel joints
- Suitable for thickness between 18mm and 28mm
- For use with DOMINO DF 500 jointer and BS-KV D15 jig
The DOMINO D8/50 connector locks together furniture corner joints or ‘L’ panel joints. It is suitable for materials with a thickness between 18mm and 28mm. The joints are easy to assemble, disassemble and reassemble being strong, tight and unobtrusive.
With the DOMINO DF 500 jointer and BS-KV D15 jig you can produce highly accurate and strong knockdown joinery simply and quickly. Machining is precise and quick, the system offers increased flexibility, design potential and savings in time. Supplied as a pack of 50 connectors.
- Produce highly accurate and strong knockdown joinery
- Precise and quick system
