Festool DOMINO DF 500 Corner Connector KV-LR32 D8/50
- Pack of 50 DOMINO furniture connectors
- For furniture mid panel joints or ‘T’ panel joints
- Suitable for thickness between 18mm and 28mm
- For use with DOMINO DF 500 jointer and BS-KV D15 jig
- Produce highly accurate and strong knockdown joinery
- Precise and quick system
The DOMINO KV-LR 32 D8/50 connector locks together furniture mid-panel joints or ‘T’ panel joints. It is suitable for materials with a thickness between 18mm and 28mm. The male half locates in a 5mm hole or the pre-drilled holes of the 32mm cabinet system. The female half fits into a hole made by your DOMINO DF 500 jointer and BS-KV D15 jig.
The joints are easy to assemble, disassemble and reassemble being strong, tight and unobtrusive. The system allows you to produce highly accurate and strong knockdown joinery simply and quickly. Machining is precise and quick, the system offers increased flexibility, design potential and savings in time. Supplied as a pack of 50 connectors.
