From £329.98 £274.98
Low Stock
- get it Tuesday 21st Mar, order within and choose Premium delivery. Delivery info
  • Delta shaped pad for effective sanding of corners and other awkward spots
  • Significant time saving and less reworking
  • StickFix hook and loop base, economical use of abrasive
Customers Also Bought
Total:
£924.62 £770.52
The Delta sanding pad, with its pointed tip, is ideal for sanding into corners. This ability saves time and money by eliminating the need to rework these awkward spots. Weighing only 1.2kg, this sander is comfortable and controllable for single-handed use. Efficient and clean, it is easy to use even for extended periods of time. It is relatively quiet, operates smoothly and has perfect balance. The high speed and small orbit diameter of just 2.0mm leaves an excellent finish. The electronic speed control ensures the sander maintains its speed under load and transfers all 250W of power directly to the work surface. It features Festool’s reliable CLEANTEC extraction connecting system. Connecting it to a vacuum results in virtually zero sanding dust left on the surface you are sanding or in the air. Alternatively, you can use the durable, reusable long-life chip collection bag supplied with the machine. It comes in a Systainer case along with a PROTECTOR, for smooth sanding adjacent to a vertical surface and a long-life dust bag. Pad size: 100 x 150mm Delta.
  • Plug-It® removable mains cable system
  • High speed with small 2.0mm orbit
  • Supplied with dust bag and has a 27mm dust extraction outlet
  • Pad size: 100 x 150mm Delta
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.90 9
