Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool EHL 65 EQ Planer
  • Improved EHL65EQ planer
  • Compact design for single-handed use
  • Planing depth control in 0.1mm steps to max 4mm
  • Unique easy change TCT spiral blade leaves excellent finish
  • Low vibration due to precisely balanced cutter block
  • Dust extraction to either left or right
  • Full wave electronic control soft start
  • Spring-loaded parking foot prevents accidental damage
  • Fitted with overload protection
  • Automatic cut-out when brushes worn
  • Chamfering Vee groove in front platen
  • Supplied with plug-it cable, parallel guide and SYSTAINER® T-LOC case
  • Show More
£278.96 (£232.47 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Festool 3 Year Warranty (Registration Required)
Upgraded version of the EHL 65 Festool Planer with a more compact design and other small improvements to make the machine more refined. The cutting block is fitted with a ground solid carbide blade that gives a shear cutting action across the width of the planer block resulting in a very fine finish. Maximum cutting depth of 4mm (accurately controlled in 0.1mm steps), this machine offers fast waste removal with easily handling. Although using only a single blade, the balance of the cutter block is very fine reducing vibration to a minimum. Changing the blade is simple and no further settings are required. The overall size and layout of the planer make it very easy to use single-handed. Supplied complete with parallel side fence, plug-it cable and SYS 2 T-LOC case.
Information Downloads
Specification
Specification
Corded or Cordless Corded
Dust Extraction 27 mm Outlet
Max Depth of Cut 4.0 mm
Max Rebate Depth 23 mm
Model EHL 65 E-Plus
Motor Power 720 W
Nett Weight 2.4 kg
Number of Knives 1
Planing Width 65 mm
Rating Industrial
Sound Power Level [Uncertainty K] 88 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 77 dB(A) [3.0 dB]
Cutterblock Speed 15,600 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
