Festool ETSC 2 150-Basic Eccentric Sander 18V (Body Only)
- Cordless offers maximum freedom of movement
- Brushless EC-TEC Motor: High power and long service life
- Stepless speed control adjusts sanding speed for different materials
- Comfortable handling during extended use
- Integrated dust extraction keeps workspace clean and healthy
- Works with Festool's range of sanding pads and abrasives
- Supplied in a SYS 3 M 187 T-LOC Systainer
The Festool ETSC 2 150-Basic cordless Eccentric Sander is a versatile and powerful tool designed to meet the needs of professional woodworkers and DIY enthusiasts alike and is fitted with a 150mm diameter sanding pad. Powered by a Festool 18V Li-Ion battery (not supplied) this cordless sander offers the freedom to work without the constraints of a power cord, making it ideal for both workshop and on-site projects. Its compact and ergonomic design ensures comfortable handling, even during extended use, while the powerful 18V battery provides consistent performance for smooth and efficient sanding.
The ETSC 2 150 is equipped with a brushless EC-TEC motor, which delivers high power and long service life while consuming extremely low amounts of energy, ensuring that you can rely on this sander for years to come. The Festool ETSC 2 150 is known for its precision and ease of use. The sander features a stepless speed control, allowing users to adjust the sanding speed to suit different materials and applications. This ensures optimal results, whether you are working on delicate surfaces or removing large amounts of material.
Additionally, the integrated dust extraction system, combined with the turbo dust extraction feature, keeps your workspace clean and free from harmful dust particles, promoting a healthier working environment. The ETSC 2 150 also includes an antistatic function to prevent static charge from accumulating when working. The sander is compatible with Festool's extensive range of sanding pads and abrasives, providing versatility and convenience for a wide range of sanding tasks. These include tables, surfaces, doors, door frames, window bars, indoor and outdoor steps, wooden parts, wooden cladding, eaves, small areas in dry mortarless construction, spot repairs, craft projects, fences, balcony boards, and much more.
Moreover, the ETSC 2 150 comes with several advanced features to enhance its performance and user experience. The protector feature safeguards the sanding pad and material when working close to edges. The vibration protection ensures particularly high balancing quality for optimum smooth running when sanding and additional speed reduction in the event of high vibrations, allowing you to work in a way that protects your health. The StickFix STF system offers a quick and economical fastening system for abrasives – no adhesives, no clamping. Additionally, the patented MULTI-JETSTREAM 2 principle integrates a dust conveying system for efficient sanding.
Supplied with a Multi Jetstream 150mm sanding pad, pad protector and collection bag packed in a SYS3 M 187 T-LOC Systainer Case. Part of the Festool 18V Li-Ion family.
