Festool Gecko Suction Set
493507
493507
- Carrying capacity 50kg
- Four location points for attaching other accessories
- Adaptor for the guide rail easily fitted to the dual suction pad
- Suction pads can be changed without the use of tools
- Supplied with adaptor to fit guide rail
This suction lifter has a carrying capacity of 50kg and is fitted with clamping levers for quick reliable suction. It also has four location points for attaching other accessories and an adaptor for the guide rail can be easily fitted to the dual suction pad. The pads can be changed without the use of tools and each one also has a sliding point so that it can be released easily. Supplied with adaptor to fit guide rail. Please note; suitable for smooth non porous surfaces such as laminate and glass.
