Festool Granat Abrasive 150mm Disc Starter Set
111657
Special Price £49.98 £41.65 was £60.98 £50.82 Save £11.00 £9.17
1 Review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 19th Jun
  • 10x GRANAT sanding discs in grit sizes P60, P80, P120, P180, P220, and P320
  • Will fit 150mm sanders
  • Work with minimal dust thanks to the MULTI-JETSTREAM 2 system and 49-hole extraction
  • Special coating and hole pattern prevents clogging and ensures a long service life
  • Ideal for use with repair compound, filler, varnish (especially VOC varnishes and hard base layers)
  • FSCâ„¢-certified
Discover the power of Granat abrasives with the Festool Granat D150 starter set. This set offers a comprehensive introduction to the world of Granat abrasives, with varied grit sizes ranging from coarse to fine, providing the perfect support for a wide range of projects. Experience the high quality and exceptional performance of Granat abrasives first hand, with 10 of each grit GRANAT sanding discs in grit sizes P60, P80, P120, P180, P220, and P320 - the perfect addition to your sander.
Thanks to the MULTI-JETSTREAM 2 system and 49-hole extraction, you can work with minimal dust, protecting both the surface being processed and your health. Specially designed for use with VOC varnishes and hard substrates, with a special coating and hole pattern that prevents clogging and ensures a long service life. Ideal for use with repair compound, filler, varnish (especially VOC varnishes and hard base layers). FSCâ„¢-certified.
Will fit 150mm sanders.
5.00 1
