Festool Groove Unit for HK85 Saw
- Turns a Festool HK85 saw into a portable slotting and grooving machine
- Adjustable width grooves or dadoes 16 to 25mm wide, up to 35mm deep
- Rapid waste removal, high quality surface finish
- Adds more versatility to the HK85 saw
- Supplied with all necessary safety guards
- Reversible, solid carbide HW-WP 14 x 14 x 2 blades
- Supplied with blades, safety guards, flanges and SYSTAINER case
The VN-HK85 turns your Festool HK85 saw into an effective, portable slotting or grooving machine. Installed onto the side of the saw unit, complete with all necessary safety guards, it adds even more versatility to your machine. Using the VN-HK85 you can cut grooves or dadoes between 16mm and 25mm wide and up to 35mm deep. The reversible, solid carbide HW-WP 14 x 14 x 2 blades rapidly remove waste material, leaving a high quality surface finish. Intermediate spacing rings govern the width of the groove; set up is quite simple. Supplied with blades, safety guards, flanges and SYSTAINER case.
