More deals added in
Have you clocked our Christmas Countdown deals?
Festool HKC 55 LI 5.0 EBI-PLUS Circular Saw Bluetooth 18V
105622
From £702.98 £585.82
Low Stock
- get it Saturday 9th Dec, order within and choose Premium delivery. Delivery info
  • Supplied with 2 X 5.0Ah batteries
  • Bluetooth batteries for auto switching of compatible extractor
  • Saw features 55mm depth of cut, rip or cross cut
Customers Also Bought
Exhibiting the true capabilities of an innovative, cordless circular saw
Wherever you require repeatable angled cuts, this capable and impressive circular saw will always make the cut. With the option to add a guide rail, its versatility is unmatched.
Powerful EC-TEC motor
Thanks to the impressive EC-TEC motor, you can achieve perfect results, faster. Delivering more than enough power for its 55mm maximum depth of cut, the HKC 55 will help you to be unstoppable. Extremely robust, the brushless motor requires less maintenance, resulting in an extended battery life. Whilst packing plenty of power, the motor doesn’t use a lot of energy to deliver this, so you’ll be good to go all day.
Excellent cutting performance
An ideal companion for rip or cross cuts. The HKC 55 saw can make achieving precise plunge cuts, look easy. Simply push the lever and set the desired cutting depth using the clearly visible and easy-to-read scale, then release. It’s so easy to reach the exact depth, easily and conveniently.
FastFix blade change
Festool’s FastFix blade change feature allows for quick, one-handed changes, without the need for additional equipment or manual tool changes. Festool always think of the user and how they can make the job less time-consuming. When a job requires quick tool changes, this feature is saves time and improves the quality, by working with a blade that’s matched to the material. A hinged blade cover allows clear blade and cut line visibility.
Even more versatility
More independence calls for more precision and the possibilities are endless, with such a capable machine such as this. Elevate your projects to new heights, working from a roof? The FSK Cross-cut Guide Rail will help demonstrate this ascend with ease. Available in three lengths and easy to set up; you’ll have a mobile compound mitre saw system for accurate angled cuts to-hand whenever you need it.
Bluetooth compatibility
Clever as a system, the Li-HighPower compact battery available, includes the latest Bluetooth technology. Festool always thinks of the small details that make a big difference. The battery communicates with a Festool mobile dust extractor fitted with a bluetooth receiver. The benefit? It switches on and off, in accordance with the cordless tool that it is paired with. Saving you time and effort.
Convenient and safe
Handle this machine safely, thanks to the cutting depth adjustment with plunge-cut function, remote control of the suspended cover and guide wedge angle adjustment from 0 to 50°.
MyFestool
For your added support, Festool offers a comprehensive service plan once you register your tool. Enjoy the following benefits with the Warranty all-inclusive:
  • Free repairs for three years
  • Fast resolution directly from Festool
  • Replaced in the event of theft
Part of the faultless Festool system
The 18V cordless lineup from Festool is quite simply brilliant. Always thinking of all the small details, Festool helps you achieve tasks more efficiently, and with plenty of power. Whatever your project demands, this range will most likely have the tool for it.
  1. Festool HKC 55 LI 5.0 EBI-PLUS Circular Saw Bluetooth 18V
Total:
£2,456.92 £2,047.43
This HKC 55 cordless saw comes with 2 X 5.0Ah Bluetooth batteries. When used with an extractor fitted with a Bluetooth receiver, you get the unique advantage of automatic switching, while using a cordless tool. There’s no longer any need to walk back and forth to the extractor to turn it on or off.
The EC-TEC® brushless motor coupled with the 5.0Ah battery delivers more than enough power for the saw's 55mm maximum depth of cut. The HKC 55 is ideal for rip or cross cuts. The HKC 55 saw can make plunge cuts, simply push the lever and set the desired cutting depth using the clearly visible and easy-to-read scale, then release. You can make plunge cuts to an exact depth easily and conveniently. The angle adjustment with central clamping mechanism allows bevel cuts from 0 to 50°. The FastFix® blade change allows quick, one-handed tool-less changing of the blade, saving time and improving quality by working with a blade matched to the material. A hinged blade cover allows clear blade and cutline visibility.
Supplied with 2 x BP 18 Li 5.0 ASI battery packs, SCA 8 rapid charger, HW standard saw blade W18, operation tool and a Festool SYS3M 337 T-Loc case.
Registering the saw for an extended warranty includes a 3-year warranty on the batteries.
Please note Festool 5.2Ah battery will be re-badged 5.0Ah, there is no noticeable change to battery capacity and this is a rolling change made by Festool.
  • Makes plunge cuts to an exact depth easily and conveniently
  • FastFix® blade change for quick, one-handed tool-less changing of the blade
  • Hinged blade cover allows clear blade and cutline visibility
  • Compatible with Festool FSK and FS guide rail systems for ultimate versatility
  • Supplied with 2 x BP 18 Li 5.0 ASI battery packs, SCA 8 rapid charger, HW standard saw blade W18, operation tool and Festool SYS3M 337 T-Loc case
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Original parts guaranteed
  • 14 day money back
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
