Festool HKC55 LI 5.2 EBI-PLUS Saw Bluetooth & FS1400 Guide Rail 18V
720642
Free Extras
£684.96 £570.80
Free Festool 18V 5.2Ah AIRSTREAM Bluetooth Battery worth over £100!! (Offer Restricted to UK only) While stocks last.
Low stock
- get it Friday 25th Sep, order within and choose Premium delivery. Delivery info
  • Festool HKC 55 LI 5.2 EBI-PLUS 18V Circular Saw
  • Bluetooth batteries for auto switching of compatible extractor
  • Saw features 55mm depth of cut, rip or cross cut
Customers Also Bought
Free Festool battery with 18V tools!
Buy this Festool 18V tool and get a FREE 18V 5.2Ah AIRSTREAM Bluetooth® battery while stocks last
Package deal comprises a Festool HKC 55 LI 5.2 EBI-PLUS 18V Circular Saw with Bluetooth batteries and an FS1400 1,400mm Guide Rail
The saw comes with two 5.2Ah Bluetooth batteries. When used in conjunction with an extractor fitted with a Bluetooth receiver, you get the unique advantage of automatic switching, whilst using a cordless tool.
The EC-TEC® brushless motor coupled with the 5.2Ah battery delivers more than enough power for the saw's 55mm maximum depth of cut. The HKC 55 saw can make plunge cuts, simply push the lever and set the desired cutting depth using the clearly visible and easy-to-read scale. The angle adjustment with central clamping mechanism allows bevel cuts from 0° to 50°. A hinged blade cover allows clear blade and cut line visibility.
Supplied with two BP 18 Li 5.2 ASI battery packs, SCA 8 rapid charger, HW standard saw blade W18, operation tool and a SYS 4 T-LOC SYSTAINER case.
Registering the saw for an extended warranty includes a 3-year warranty on the batteries.
FS1400 Guide Rail
The combination of the HKC 55 the FS1400 Guide Rail creates a superb system for cutting sheet materials. The guide rail has two PTFE strips embedded into it allowing the tool to glide smoothly on the rail. On the underside of the rail, there are two neoprene strips, which hug the surface of the material, reducing slippage. There is also a special rubber strip on the underside, which minimises splintering on the top surface of the board. Length 1,400mm.
  • Makes plunge cuts to an exact depth easily and conveniently
  • Hinged blade cover allows clear blade and cut line visibility
  • Supplied with Two BP 18 Li 5.2 ASI battery packs, SCA 8 rapid charger, HW standard saw blade W18, operation tool and SYS 4 T-LOC SYSTAINER case
  • Festool FS1400 Guide Rail
  • Converts HKC saw into a system for cutting sheet materials
  • Two embedded PTFE strips help saw glide
  • Two underside neoprene strips to reduce slippage
  • Splinter strip minimises splintering
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
