Festool Hose Connector with Adjustable Airflow D 27 DM-AS/CT
- Quick and secure connection
- Infinitely adjustable bypass for setting airflow
- Match the airflow to the tool or task for efficient extraction
This connecting sleeve fits neatly between the extractor’s suction hose and the extraction outlet on your Festool power tool. The connection is quick and secure and it can be detached equally quickly.
The connecting sleeve features an infinitely adjustable bypass, which allows you to set the airflow rate to suit the power tool in use or particular task.
It enables you to work efficiently with different tools, cleanly and systematically. The bayonet fitting prevents the suction hose from slipping off the power tool. The compact design won’t interfere with the handling of the power tool and the rotating adapter prevents the hose from twisting.
EAN Barcode | 4014549401309 |
Manufacturer Part Number | 577162 |
Model | D 27 DM-AS/CT |
