Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool KAPEX KS 120 REB SET Mitre Saw & MFT Base
  • A complete mitre saw workstation in one package
  • Cuts boards and panels up to 305mm x 88mm
  • KAPEX KS 120 REB mitre with impressive cutting capacity
  • Uncompromising accuracy at any angle
  • Versatile MFT KAPEX multifunction table
  • Includes R & L extensions each with maximum support of 2,400mm
  • 2 x crown stops support crown moulding or cornice
  • Adjustable transfer bevel measures and divides mitre angle
  • Show More
£1,946.96 - £1,997.96 (£1,622.47 - £1,664.97 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Festool 3 Year Warranty (Registration Required)
The KAPEX KS 120 REB SET forms a complete mitre saw workstation in either your workshop or on site. It comprises a KAPEX KS 120 REB mitre saw, a multifunction table MFT KAPEX, R and L trimming attachments, 2 x crown-stops, a hold-down clamp, an adjustable transfer bevel, 60-tooth blade and tool kit.
The KS 120 REB saw offers an impressive cutting capacity and uncompromising accuracy. It is capable of cutting boards and panels up to 305mm wide and 88mm thick. It features 11 preset mitre angles and a twin-line laser beam that shows you precisely where the blade will cut. Variable speed means you can adapt to different materials for the best cutting performance. Pull-out side extensions provide extra support to longer workpieces.
The saw fits directly onto the multifunction table MFT KAPEX giving a working height of 900mm. The table has a perforated top enabling you to use a wide range of accessories such as the Parf system. The table legs fold for transport or storage.
The left and right extensions fit to the base frame and both are 1,480mm in length. They have a telescopic extension giving each a maximum support length of 2,400mm, complete with measuring scales and length stops.
The crown stops support crown moulding or cornice at the correct angle for cutting perfectly accurate mitre joints.
Promo
Achieve the perfect cut with this impressive sliding compound mitre saw
Additional tool features
For more efficient working, the extra mitre position makes cutting depths up to 120mm possible. Intelligent details like a double laser line and bevel produce exact results.
Even more versatile
Even more versatile
Enjoy flexible working thanks to the pull-out extension table and accessories for crown mouldings and wide workpieces.
Ideal for long workpieces
The individual pull-out extension table allows for secure and precise positioning of even long workpieces.
Crown stop
Crown stop
With the crown stop, trimming attachments and base frame, cutting crown mouldings is simple. For convenience, it can also be used as an extension table.
Specification
Specification
Bevel Angle Range 47° - 0 - 47°
Blade Diameter 260 mm
Bore Size 30 mm
Dust Extraction 27 mm / 36 mm Outlet
Electric Brake Standard Feature
Mitre Angle Range 50° - 0 - 60°
Model KS 120 REB
Motor Power 1,600 W
Nett Weight 21.5 kg
Overall L x W x H Saw 713 mm x 500 mm x 470 mm
Rating Industrial
Sound Power Level [Uncertainty K] 101 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 93 dB(A) [3.0 dB]
Spindle Lock Standard Feature
Max Bevel Cut @ 45º W x H 305 mm x 40 mm
Max Compound Cut @ 45º W x H 215 mm x 55 mm
Max Crosscut @ 0º W x H 305 mm x 88 mm
Max Mitre Cut @ 45º W x H 215 mm x 88 mm
Blade RPM 1,400 - 3,400 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
