Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool KAPEX KS 60-UG-Set Mitre Saw + UG Frame
  • Festool KAPEX KS 60 E-SET Mitre Saw
  • Professional quality guarantees precise results
  • 60° mitre L and R with indents for common angles
  • 47° L 46° R bevel cutting
  • Large capacity 305mm crosscut, 60mm depth
  • Integral extension tables for long workpieces
  • Set version includes:
  • LED spot light for improved sighting of cut line
  • Bevel for exact angle setting of saw for skirting and cornice
  • Additional feet to raise table height that of SYSTAINER SYS 1 case
  • Festool UG-KS 60 Base Frame for KAPEX KS 60
  • A complete mitre saw workstation system
  • Quickly folds down, mitre saw remains attached
  • Large diameter wheels for easy transportation over rough surfaces
  • Levelling feet for use on uneven surfaces
  • Comfortable working height of 900mm
  • Show More
£939.96 - £972.96 (£783.30 - £810.80 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Festool 3 Year Warranty (Registration Required)
This package deal comprises a Festool KAPEX KS 60 E-SET Mitre Saw and a Festool UG-KS 60 Base Frame
The Festool KAPEX KS 60 combines portability with Festool’s faultless build quality. It has a compact and lightweight design, with an integrated cord holder and locking device for safe transportation.
This professional compound mitre saw guarantees accurate results on site or in the workshop. It will swivel to 60° on both sides with indents at 0°, 15°, 22.5°, 30°, 45° and 60° for quick setting of common angles. The head tilts for bevel cuts 47° to the left and 46° to the right, with stops at 45° for fast setup.
The KS 60 is capable of crosscutting up to 305mm wide and trimming strips, profiles and square timber up to 60mm thick. The electronically controlled smooth start-up ensures that the machine starts up jolt-free. Variable speed control, from 1,300 to 3,500rpm, allows you to adjust the saw’s speed to the material you wish to cut. Integral extension tables on both sides, pull out to support longer workpieces.
The KAPEX KS 60 E-SET comes with 3 very useful accessories. A set of additional feet raises the KS 60 table to the exact height of a SYSTAINER SYS 1 case. This enables you to support long workpieces, without the need to scrabble around for odd packing pieces. The LED spotlight gives you a perfect view of the cutting line, especially useful in poorly illuminated situations. The cleverly designed bevel guarantees you fault-free angle transfer both internal and external. The bevel automatically bisects an angle allowing you to set the KAPEX KS 60 precisely when cutting skirting boards or cornices.
With the UG-KS 60, you can turn your KAPEX KS 60 compound mitre saw into a complete mobile, mitre saw workstation. The combination is practical and robust resulting in portability with stability.
Attaching the KAPEX KS 60 to the base frame is very simple, and the mounting plate features convenient, safe storage for a spare saw blade. There is no need to remove the saw for transport; the saw and base are very compact when folded down. Two large diameter wheels make it easy to move the frame over rough surfaces or up kerbs or steps. The folding support frame doubles up as a handle for transporting the machine. Set up is extremely fast and easy and levelling feet ensure complete stability on uneven ground. Once set up the working height is a comfortable 900mm.
Right and left material support extensions with measuring scales are also available.
Specification
Specification
Bevel Angle Range 47° - 0 - 46°
Blade Diameter 216 mm
Bore Size 30 mm
Dust Extraction 27 mm / 36 mm Outlet
Electric Brake Standard Feature
Mitre Angle Range 60° - 0 - 68°
Model 575339.0
Motor Power 1,200 W
Nett Weight 17.8 kg
Overall L x W x H 661 mm x 475 mm x 430 mm
Rating Industrial
Sound Power Level [Uncertainty K] 100 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 91 dB(A) [3.0 dB]
Spindle Lock Standard Feature
Max Bevel Cut @ 45º W x H 305 mm x 40 mm
Max Compound Cut @ 45º W x H 215 mm x 40 mm
Max Crosscut @ 0º W x H 305 mm x 60 mm
Max Mitre Cut @ 45º W x H 215 mm x 60 mm
Blade RPM 1,300 - 3,500 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
