Festool Li-Ion AIRSTREAM Battery 18V (5.2Ah)
- Individually selected lithium-ion cells for optimal charge and discharge cycles
- Higher capacities give longer run times
- Especially effective in high-energy applications
Customers Also Bought
The lithium-ion cells used to make up Festool's cordless batteries are individually selected to exactly match one another. The result is a balanced load with absolute optimal charge and discharge cycles. The Festool AIRSTREAM battery has a capacity indicator allowing you to check the amount of power that is left in the battery. Pressing the green button on the AIRSTREAM battery gives you an indication about the battery's charging status. With the battery inserted into its charger you get an indication when charging is complete. The unique feature of the AIRSTREAM battery is its air cooling system, when used together with the FESTOOL SCA 8 rapid charger. The SCA 8 charger draws cooling air through the AIRSTREAM battery, reducing charge times by up to 65% compared to conventional chargers. Festool AIRSTREAM batteries are compatible with all Festool Li-ion cordless tools and chargers with corresponding voltages.
Please note: Festool Batteries and battery chargers cannot be registered on Festool website as they automatically benefit from Warranty all-inclusive. For batteries and battery chargers purchased as accessories a copy of the invoice serves as proof.
- Capacity indicator for checking remaining charge
- Compatible with Festool Li-ion cordless tools with corresponding voltage
