Festool LR 32-SYS Hole Drilling Set
102581
From £573.68 £478.07
5 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 16th May
  • Efficient and accurate hole-boring system, easy to set up and use
  • Designed for Festool OF 1010 or OF 1400 router
  • Portable line boring system allows you carry out work on site
  • Results far surpass any other shelf-drilling jig
  • Increases productivity with greater accuracy
  • Requires an additional guide rail with holes series LR 32
  1. Festool LR 32-SYS Hole Drilling Set
Total:
£1,878.42 £1,565.35
The Euro 32mm system of cabinet design and construction uses rows of 5mm holes drilled on 32mm centres. The boring of the system holes in the cabinet side panels requires a high level of accuracy. Typically, panel production uses large stationary in-line boring machines or CNC router tables. For the small cabinetmaker or bespoke kitchen builder the Festool LR 32-SYS Hole Drilling Set offers you an accurate hole-boring system that is easy to set up, efficient and easy to use. This portable line boring system allows you to carry out work on site that traditionally would only have been possible with large stationary equipment. Festool recommend using either their OF 1010 and OF 1400 router. The system also requires an additional guide rail with holes series LR 32. The results far surpass any other shelf-drilling jig, being far more accurate. With increased productivity and greater accuracy, items such as this pay for themselves quickly through faster production times and quicker job turnaround. Included in a Systainer case are guide plate, centring mandrel, operating wrench, 35 mm carbide-tipped European hinge boring bit, 2 carbide-tipped 5 mm shelf pin bits (one for through holes and one for stopped pin holes), 2 parallel side fences with adjustable stop, 2 longitudinal stops and 2 FSZ 100 clamps.
4.80 5
