Festool MINI 3 TL Systainer T-LOC
- Quality design to protect the contents
- Neat and secure storage of small parts and hand tools
- Simple, compact transport
- T-LOC system case for ease of use
- Robust ABS with moulded ribs for strength
- Mini cases can stack and clip together
- 265 x 171 x 142mm
The Mini 3 TL Systainer® T-LOC case is twice the height of the original Mini T-LOC. It incorporates the clever single T-LOC central control, which stands for Lock, Open, Control - performing three functions in one. The Mini T-LOC cases function in exactly the same way as the large power tool T-LOC cases. You can stack and lock them together and still open them individually. These small and robust cases protect hand tools, small parts, accessories, consumable items or your lunch against dust, spray water and heavy impacts. They keep the contents safe and make transportation easy. The Mini 3 TL case is 265mm wide x 171mm deep front to back and 142mm high. Please note, it cannot be connected to T-LOC SYS 1, SYS 2, SYS 3, SYS 4, SYS 5 or SORTAINER.
