The perfect tool for your trade
At just 4.5kg, the OF1400 EBQ-Plus Router is a handy and versatile tool. Capable of superior precision, it's ideal for rounding, chamfering, rebating and profiling edges, as well as being perfect for countersinking fittings.
High precision routing
The OF 1400 boasts column clamping on both sides which makes this router extremely rigid and torsion-resistant, leading to precise results and no need for reworking.
70mm milling stroke
Thanks to its long 70mm routing stroke, the OF 1400 can easily handle large routing depths and will make light work of recessing fittings or using templates.
Finely tuned depth control
Adjust the routing depth to an accuracy of 1/10 mm with ease, thanks to the precise depth adjuster with a 20mm range.
Ergonomic design
The OF 1400 is easy to handle safely and comfortably; reach the on/off switch and variable speed control whilst using the ergonomic bar handle.
Optimum visibility
The OF 1400 boasts an LED light ring on the extraction bonnet, for a clean working area and a shadow-free view.
High-spec safety
A quick stop brake will safely bring the router to a stop in seconds. MMC electronics ("Multi Material Control") constantly monitors speed and temperature for optimum performance and safety.
Fast cutter replacement
Change the cutter without removing the key, thanks to the convenient spindle stop with rocker and ratchet principle.
Tool-free changes
Change the copying ring quickly and easily with a click-release - no tools needed.
