Festool OF 1400 EBQ-Plus Router (1/2")
- Powerful smooth running 1,400W motor
- Full wave MMC-Electronic variable speed control
- Constant load monitoring, electronic brake and soft start
- Precision depth gauge and turret stop
Maintaining the high quality synonymous with Festool, the OF 1400 EBQ-Plus is a rugged, precision router suited to all joinery, cabinet making, plastic and aluminium fabrication as well as all other routing applications. Ergonomically designed for easy, safe and comfortable handling, the 1,400W motor is controlled by MMC electronics incorporating variable speed, soft start and electronic braking. Rocker/ratchet spindle; no need to remove spanner when changing cutter.
Supplied with 1/4" and 1/2" collets, extraction hood, side fence with fine adjuster, collet spanner, 30mm guide bush, T-LOC SYSTAINER® SYS3 M 337 stacking storage case.
- Single point fence rod clamping
- c/w fence with fine fence adjuster
- Extraction attachment
- 1/4" and 1/2" collets and 30mm guide bush
- Festool T-LOC SYSTAINER® SYS3 M 337
